Sign in to follow this
Guest skin76
Saturn Aura
dude, grab the top of the door panel and pull it back enough to pull out the "rub rail"....then pull out the rubber around the sides and top of the doors.....
a great deal of the new cars you can pull back the door panel and pull out the rubber or just pull back the door panel.
Share this post
Link to post
I pulled the door panel back and pulled out the rub rail and seals around the window. but had major problems trying to get the top of the door panel back up and over the rub rail when I tryed to reinstall the seals. end up having to pull the panels. anyone have a trick to prying them back on
Share this post
Link to post
some of them can be tough to get back over the gasket. Somtimes it takes brute force. Somtimes you can get away with taking and screws out of the top of the panal to give it some play.
Share this post
Link to post
the backglass is basic...need a bulldozer for the rear breaklight.
the rubbers come out at the bottom of the roll-ups and all around the window. makes for a nice eazy install.
:coffee
How about the lines on top of back glass where they a problem to lay down?
Share this post
Link to post
Usually you just have to muscle it back on. Start with the front or back, and get it over, then pull back with a lot of force on the next bit and "bump" it hardly with your fist to slip it back on and work your way down the panel.
Share this post
Link to post
