Sign in to follow this
TintWizard
2003 Ion 4dr. any problems?
LOL..I useto go on Llumartech all the time..till I started hanging around here in TD! :shock I'll check that out, thanx for the heads up! :rollin
Share this post
Link to post
Guest metint
LOL..I useto go on Llumartech all the time..till I started hanging around here in TD!  :shock I'll check that out, thanx for the heads up!  :shock
Funny :spit I find myself doing the same.
Probably cause this place is more to the moment than the other.
:rollin
Be sure to ask for the acrylic adhesive when ordering and get 1 1/2 inch width not 1 inch. Acrylic can stand higher temps.
Good luck :spit
Share this post
Link to post
TW that car is pretty easy, the front door glass shifts a little, not as bad as a cavalier, the quarter windows SUCK :shock....the weatherstrip is big and blocks some of the glass, I have only done like 2 of them and didnt have time to experiment with the best way to tint the quarters so they look really really good. hope this helps :rollin (other than that, they're easy)
Share this post
Link to post
sounds good Zro..so you had no concerns with tint scratching with plastic gaskets I'm hearing about?
Share this post
Link to post
:hmmm OK..so here I am posing a yr after my last post..I finally had one of these things in (rare around here) easy as pie ! Easy 1 peice shrink, no screws to remove, all panels pull back from the top, rubber pulls off easy off the borders for easy install of doors and 1/4 windows and no scratching issues :DD
Share this post
Link to post
