armolanusa.com
tintwiz.com
“Patterns.3M”
Xpel
suntekfilms
spacer
armolanusa.com
tintwiz.com
Patterns.3M
Xpel
suntekfilms.com
spacer
Sign in to follow this
Guest MAGIC2006
huper optik window films
Guest Rama
Huper films are Awesome!! They do have exclusive territories. I was lucky enough to get one. As for specs, try the Drei- 35% film that cuts 70% of the heat at 12% reflectance....the same shine as glass. The ceramic films don't cut as much heat as this one but they are up there! Ceramic 30 cuts 60%+- at 9% reflectance....less reflective then glass!! Show these to a customer and they will almost always go with Huper even tho it is usually double the cost!
Edited by Rama
Share this post
Link to post
Guest Sunshade
Huper what? :jerkit
Oh yeah, I'm a 3M guy, that's why I don't get it :hmmm
Share this post
Link to post
Guest metint
Er... sceeeuuzzz me(tint)... correction please... clear glass reflectance falls between 8-9%.
Now about Hu Op...
Are those their (huper's) numbers or an independent?
Edited by metint4u2
Share this post
Link to post
Guest Litespeeds
The Huper Optik ceramic films have around 8% visible light reflectance and that is about the same as glass. The DREI or SECH line is a full metal film and has a greater reflectance than glass. I haven't installed any of the DREI or SECH film but have seen some samples.
Share this post
Link to post
Guest Rama
I have installed Drei and it is not reflective at all. If you want to argue the point over 8 or 12% go for it, I am not nearly as up on stuff like that as you are metint. As far as it being independantly tested, I could care less, performance doesn't lie, nor do digital heat meters. When tested side by side with other similar products Drei beats them hands down.
Share this post
Link to post
Guest H?perOptik
Now about Hu Op...
sorry for the late post.
reflectance on clear glass does fall between 8-12%, depending on the type of glass and its thickness, so I guess both of you are right. in any case, DREI's IR rejection/reflectivity ratio compared to other films with the same VLT is much higher (thats why the high cost hahahaha j/k)
the spec numbers are based on ASHRAE and ISO9050. you are more than welcome to check them out yourself. Pls obtain a sample from your HO rep, or email me your address and I will send some to you.
cheers!
Share this post
Link to post
Lite,
Pardon me for still being puzzled with your Stark usuage.
Have you actually fitted up the Stark 30 (no other alternative VLT's) and not had blushing, radio interference, nor increased reflectivity externally?
devil
Share this post
Link to post
Guest TINTFXold
Huper what? :rollin
Oh yeah, I'm a 3M guy, that's why I don't get it :thumb
this we knew :thumb :thumb :hmmm
Share this post
Link to post
Guest tintslut
This struggla been stikin huper longer than LS, NO DETRIMENT TO RF!
Share this post
Link to post
