Sign in to follow this
Guest tint51
Shaved door handles
Guest tint51
Anyone shaved door handles before??
Chopped a roof?
Suicided doors???
Share this post
Link to post
Guest tint51
yep?
you need some info?
I have a 56 bug I want to Do all to..
any info or problems.. I have an article from 1988 on doing suicide door using toyota hidge with mod..
Roof chopped From www.runtron.com doing it a 70's style..
Share this post
Link to post
Guest tint51
make sure u know somebody to cut you glass, its not that hard on that car cuz the ones you will cut are flat. the backglass is usually moved down
Yes, I agree luckily the way I want to do it I will be having only flat glass to cut but not the back... () ...
going to slice behind in middle of rear quarter and drop the roof down about 3in..the whole roof will not be cut to pieces..
Just take your time and do it right. Nothing worse than a sh***y chop/shave
This is true... I have been doing a lot of research..
Edited by tint51
Share this post
Link to post
Guest pedro
im in the UK at the moment,
sounds like a nice project if your any good with a welder the shavings easy,
suicide doors would be good, just source a kit from maybe autoloc, or I was thinking about using hinges from the black cabs we have here in the UK,
cheap from a breakers,
you might need to reinforce the pillar if the doors weighty.
Share this post
Link to post
Chopped a roof?
Suicided doors???
I've shaved door handles on a eclipse once, but the guy I did it for already had the remote door openers on the car so it was a fairly simple procedure.
Share this post
Link to post
Guest tint51
I have a good article in hotvws from may of 88' But what is ablack cabs I don't think we have those here.. the article uses Toyota 75-80' pickup hingeage..
Share this post
Link to post
