Sign in to follow this
Followers 0
shadowline
Alfa 147 2005
3 posts in this topic
Right guys, done a few 3 doors of these, this was the first 5 door one.
Door card removal is as follows; Bottom of the door X2 screws not hidden. Remove ash tray X1 screw behind that. Remove cover by the door release handle to reveal X1 screw. Then lift out electric window switch on torx bolt behind the pull handle, the top of internal door pull handle, remove the top cover and remove the top torx screw. Then release from the lower part of the door card and lift off the top of the card, weather strip comes off attached to the door card. Job done!
Share this post
Link to post
Sorry, should have said SunTek Carbon 18 installed on that one!!
Share this post
Link to post
Followers 0
