wfctevent.com
Express Window Films
spacer
wfctevent.com
spacer
Sign in to follow this
Guest nichole87
Is Johnson's window film a good film?
Guest nichole87
I had my two front car windows tinted with 35% Johnson tint and had their clear UV film put over the windshield. I did not do my research before getting this film and now I'm hearing that Johnson's window film isn't very good. I'm worried that it's not blocking UVA rays as well as other films. Should I get the films removed or replaced with somthing else?
Thank you in advance!
Share this post
Link to post
I would say good ... but not great IMO. They have different series of film also, so it depends which one you had installed.
Share this post
Link to post
Guest nichole87
Thank you for the replys!
How long does the uv protection on these films usually last?
Share this post
Link to post
Some shops carry a uv meter to verify rejection. Your windshield already blocks 95% or so of uv a&b, so the film you got from Johnson will only improve that number. Your side windows are the ones that benefited the most. The film's uv rejection should last years, but again have a shop somewhere in your area verify every couple of years.
Share this post
Link to post
Going by another manufacturers data, the UV rejection should only have about a 2% change over a 5 year period. Either way, I with everyone else, the film should last with no problems , and Johnsons is a larger manufacturer, so its a good choice compared with some of the no name junk on the market. Im not thinking johnsons is is the business of making junk and ripping people off IMHO.
Share this post
Link to post
i have always had really good luck using johnson film. i used them first at a shop i started at years ago. i have also used about every other film out there since then. the other shops i had worked at wouldn't take a chance with their film. however i have gone back to using johnson film for comm/res, as well as for my automotive film. good easy to work film, and i can apply it with way less shampoo then any other film i have ever installed.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
