Sign in to follow this
Followers 0
TurboTinting
Testing the new film "handler"
26 posts in this topic
Ok, so I am testing out the new machine, which is not a film handler. I have yet to pull any film from it yet mainly because I am almost afraid to. The bar that holds the film is very very flimsy. As you can see, I have a 48" roll on it sitting in the middle so you can see the bow in the bar. Also, you cannot put the film in the middle of the machine, or at least I havent quite figured out how to do so. If I pull the film as it sits, its possible the bar holding the film will slide out of its mount. It is designed to put the film all the way to the left, which isnt a good idea. All that does is make the ladder want to fall over when you pull the film.
They are sending a beefier bar to hold the film, but they need to also send another collar to lock the bar in place while the film sits in the middle. There are three collars. Two are used to lock the bar in place, and the other is used to hold the spindle on the right side tight to the film. There is a "bumper" of sorts on the left side keeping that one at the 0 mark on the ruler.
As far as the cutting heads, they are difficult to slide across the bar. A little grease would work, but then it gets everywhere. My suggestion would be to add three small rollers on the inside of the heads where the can slide easily across the bar...right now its just friction. I will update tomorrow after I pull some film. I saw this thing in action in Memphis and it looked terrific.
The other pain with it is loading the film. You have to pull off two collars and one spindle (or hub I should be saying), slide the bar into the core, replace the hub and other two collars, pick it up as one unit, and place back on the cutter. With heavy ass SS film, its a challenge.
Just thought you guys would like to know.
Share this post
Link to post
That machine is designed by the same guy that designed the original Film Handler, they should have put a horizontal cutter on this one like the 2 different film cutting machines I used in the past.
Share this post
Link to post
i know nothing about film handlers
Edited by OneTen
Share this post
Link to post
If they would have left the hubs on risers, this cutter would be a lot better. I cant see this working very well even with a beefed up bar. I think it would still bow with SS film. I will report tomorrow after I cut some film.
Share this post
Link to post
If the bar that holds the film was stiffer that would definitely help, one of the machines I used to use, it was adjustable were it would mount to the top of the ladder, so with heavy film like you have on that one, the ladder would not tip over if the film was on the left hand side, they should have thought of that.... :lol
Share this post
Link to post
:lol ... Perhaps even a 5th grader would know more....... :spit ...... :poke
Share this post
Link to post
Stick yer dam straight edge on the box, stab a blade, and lay come film! :lol
Share this post
Link to post
Hey TintJunkie, If you have time tomorrow, take a few more pics of that machine and post them here.
Share this post
Link to post
the one draw back I see to this design, is that it will never hold a roll of film on a 6 inch hub. And will need to be redesigned to do so. :lol
Also the bar running through the roll off film seems like it might work well for jobs when you are using the whole roll, but kind of a hassel for someone switching rolls of film several times a day.
Share this post
Link to post
The shims they provided for mine done even work, the holes are too small to fit over the core. I don't like the flimsy pipe either.
Share this post
Link to post
Followers 0
