Sign in to follow this
Followers 0
ORIGINAL
2012 VW TIGUAN DOOR PANEL REMOVAL!!
9 posts in this topic
I CAN T SEEM TO FIGURE OUT HOW TO REMOVE THE DOOR PANEL... I took off the two bottom screws and still holds on pretty tight... other than that i dont see anything.... anyone some one please.......
Share this post
Link to post
you don't have to remove 'em. lift up on the top of the panel and it pulls out of the gasket lip and then the gasket pulls right out.
Share this post
Link to post
THANKS BLADE! how about the side gaskets? do they come out? the tweeter is really close to the glaas. that was the reason for the removal
Share this post
Link to post
its a pretty standard vw panel, similar to a golf, 2 torx behind silver handle, 2 torx at bottom then pop off all the way round and lift off, there might be one or 2 really small torx screws on the side edges, not sure but should be easy enough to see if they're there, clips can be tight so as always with a vw/audi make sure you're prying the actual clip and not the panel itself
there might be one behind the tweeter cover 2, or am i confusing that with a skoda, doors are really similar
Edited by tint325i
Share this post
Link to post
thanks tint325i! you were right it has two on the bottom and two more behind the handle cover... those panels sure are tight man! those side gaskets are really far from the edge if u know what i mean... i really wanted to pull them and avoid the small crease it sometimes leaves on the sides... lucky for me it went pretty smooth... thanks guys
Share this post
Link to post
I don't pull panels or gasket's usually, but I've been seeing a lot on how easy it is. Wouldn't it be a pain to try to get the lip on the panel back inside the gasket channel? Do they really have that much play in them?
Share this post
Link to post
sometimes you have to give them some gentle "Persuasion" but like any VW they can Be a biatch or they can be a breeze one day to the next.
Share this post
Link to post
Followers 0
