Sign in to follow this
TintTriad
Hid Kit Question (Bulbs)
Looking to get into installing HID kits but I see you need different bulbs for every single car.
If the bulbs plug in directly to the ballist (The same ballist that you use on every car) and then the ballist is plugged into the car, then why does it matter what kind of bulbs are connected to the ballist?
Only need the kits to be low-beam.
Thanks!
Share this post
Link to post
Same ballast. Different bulbs for different cars. Also they come in many different color temps. Bulbs need to fit housing as they are a "retrofit".
Share this post
Link to post
I know they are the same ballist and I know that all cars have different bulbs & temps (6000K is main I will be using) but what do you mean by "retrofit"?
Share this post
Link to post
So what's the question? They are plug and play with your factory system.
Question is why can't I use the same bulbs on every car since all the car is connected to is the ballast.
Share this post
Link to post
because every head light assembly will only hold a certain style bulb.
You will find that there are only about 6 or 7 really common bulb types, but they all mount to the light housing differently.
So only difference is how the bulb mounts? So if I find a way to seal them, I am fine ordering all the same bulb. (Like 20 HID kits, all H11 bulbs)?
Thanks
Share this post
Link to post
Thanks
You might want to do some research on HID kits before you install them. I have seen HID lights conversions melt head light buckets before.
Share this post
Link to post
Even though you can seal them, the designers try to make it mimic the original bulbs and have where the arc in the hid capsule is in the same position as the filament would be in the housing. You'll get better output with the correct bulb. I'd never retrofit without the correct reflector/projector for hids.
Edited by loy
Share this post
Link to post
So there would be no way for us to keep them in stock and install same day in our shop without stocking EVERY single HID bulb for every car?
Share this post
Link to post
