tintcracker
Shaving edges with a file
So I recently started shaving edges. Its pretty easy, UNTIL... The file catches and gouges the tint. Where can I get set of files that are good for this. Anybody used a round file before, it seems like that's what I should be using. Or at the very least a file with beveled edges.
I have been using some needle files I picked up from harbor freight, but they keep snapping inside my apron.
I tried the knife method and I find it way too difficult.
So what do you guys recommend?
Share this post
Link to post
I use a flat file. Just make sure the film is tacked up real good. Also, file away from the film already shaved and not towards it if that makes sense.
Share this post
Link to post
I tried both methods, only to find myself going back to the knife.   For top edges, I use a carbon blade.
Share this post
Link to post
Use a flat file not a round one. Haven't got my carbon blades yet. Tried sometimes with Olfa AK but I find it slightly difficult, so I go back to file the egdes instead. Will practice more with knife on some spare glasses I have in stock.
Just be careful so the file don't catch to much material when you file, has happened a few times.
Share this post
Link to post
If the file is snagging the film, there is a good chance you are applying a little too much pressure on the area of film all at once unless you are trying to file the film without letting it tack up.
Share this post
Link to post
