Express Window Films
Gary_tintington
Film comparable to Suntek Carbon
19 posts in this topic
Anybody know of a good color stable, carbon, dyed/nr film that has a higher tser comparable to Suntek's Carbon? Theirs is great but scratches all the time very easily.
Share this post
Link to post
LLumar ATC, Madico Charcool, Solar Gard NR Supreme, SolarFX Ultra, 3M CS, Epress Classic Charcoal, Global QDP...
Edited by smartie2shoes
Share this post
Link to post
Hi Gary,
You will find that the Classic Charcoal has a higher TSEr through the overall range than Carbon.
You will also need to meter the films on glass to compare actual VLT readings as the Carbon has a lower VLT than it's specs when applied.
Price is comparable, quality, usability and longevity is very strong. Higher levels of service, experience and knowledge from Express.
Hope this helps.
Share this post
Link to post
All those have a lower tser. Carbons range is 42%-50%
Hmmm, if all fall in and around LLumar's ATC, then someone is fudging theirs.
ST carbon became less carbon and more about dyed when CXP came to market.
Share this post
Link to post
The Express classic charcoal has a 35-44% range am I wrong?
If you are quoting the NR specs.. The HP specs are higher.
It is a hybrid construction, as is the Carbon.
To compare Dye options you will need to compare with ST - Standard Pro. The NR Classic Charcoal leaves the standard pro in the dark ages.
There are many other options. Maybe price is an issue for you...
Share this post
Link to post
The film 'Classic Black' from Express was designed to mimik the Suntek Carbon....  except the Classic Black has a WAY better scratch coat :thumb
Share this post
Link to post
