Sign in to follow this
Followers 0
Tim myers
Tinting a grand pre i need help please
9 posts in this topic
Ok on the back window i instale the tint on the grand pre i push out the middle from left to right then push it down then up why do i get fingers on the sides and bottom i dont get it please help i try to heat them out but they crease to easy
Edited by Tim myers
Share this post
Link to post
But i did do you thank i did somthing wrong shrinking it cause i do bar soap and do a strait line in the middle then a line up and down in the middle of that so i shrink 4 square s?
Share this post
Link to post
Am i shrinking it wrong allways down then i do upper
Share this post
Link to post
If you shrank it and it laid on the outside then it is likely the way you are pushing the film on the inside.  You can make the film finger if you push it wrong.
Use the same pattern when installing as when you laid it out on the outside.
Share this post
Link to post
17 minutes ago, no ma'am said:
What year car? What film? And pics?
No pics i get it back tomorrow its an 04 i use daragon films 2pli
Share this post
Link to post
Ok ill try that suppper thanks appreciated
Share this post
Link to post
If you are anchoring it with a line up and down through the middle and side to side through the middle, this may be your problem.
anchor side to side through the middle and up and down on both side edges to form and H pattern and work 4 quarters out of that.
I read this twice and believe from what you are saying, you basically end up with a cross which is going to give you problems every time.
Share this post
Link to post
Followers 0
