pitu
2017 Range Rover.
Also, run some tape and plastic over the switches and panels. The panels can streak pretty bad depending on your slip. The switches will hold water when you rinse the bottom half, never burned one up, but I did have one act funny for a few hours. Now I make sure to cover them!
Share this post
Link to post
Always been a little scared of cutting that, but always wanted to. Once you got it back together, do u think anyone would ever be able to tell the difference?
1 hour ago, Ryker said:
Did one today.  Popped the top and cut the sweep loose.  Easy Peasey
Share this post
Link to post
Only person that would know the difference would be a body man taking the door apart.
Share this post
Link to post
Thanks, I get them here and there from the lambo dealership. It’s usually a freebie set of front doors for a manager or his family member. I definitely don’t like doing them, but with that seal out, it’ll be a much cleaner/faster install!
Share this post
Link to post
First time with rover and it’s been a challenge. So cutting the sweep any particular way? And I’m using a precut pattern any suggestions. Any advice would be greatly appreciated thanks
Share this post
Link to post
