tintwiz.com
Patterns.3M
Xpel
suntekfilms
armolanusa.com
spacer
tintwiz.com
Patterns.3M
Xpel
suntekfilms.com
armolanusa.com
spacer
HardyHarHar
Calculating final tint after tinting over factory tint
Hello,
My vehicle has factory tint on all but the two front side windows that I believe is 25% from the factory.
I wanted 12.5% so I added a tint film of 50% hoping for a final ting of 12.5%
My math was .25 x .50 = .125 or 12.5 percent (or so I thought)
The finished job BARELY looked any different from the factory tint.  It was maybe just a barely noticeable difference but I was expecting a much bigger difference.
To my eye, it looked like it went from 25% to maybe 24 or 23%
What I wanted was for it to be a bit difficult to see through.  Not quite Limo dark, but just one step up maybe.  Where did I go wrong?
Thanks
Edited by HardyHarHar
Share this post
Link to post
I don’t know the math for Tint on top Tint :hmmm
But look at it this way.  50% film is 50% darker than clear glass.  This is why you did not notice a difference.  The lower the percentage the darker the film.  70% film would be 20% lighter than the 50%.  30% film would be 20% darker than the 50%.  So on and so forth.
To achieve a 12.5% by adding to a 25% existing shade, you would need to add at least a 30% film, if not a 25%.
Share this post
Link to post
There are a number of different variables. What was the actual (meter verified) vlt of the glass to start? What was the actual vlt of the film(I've seen the actual vlt of "50%" film be anywhere from 48-58%) added? Did you also tint the front two windows? What color is the interior? You may very well be at your desired 12-14% but with a light interior and/or untinted front windows it wont make much of a difference. I've seen Tahoes/Yukons with factory privacy glass that meters 20% butted up against 10-12% and the untrained eye would never notice the difference.
Edited to add that rarely does "meter math" prove to be perfectly accurate in practice.
Edited by highplains
Share this post
Link to post
Going from 25 to 12 percent is barley noticeable to the human eye.   You need to do more like 20% over factory to really be able to "see" a difference!
Share this post
Link to post
I use my tint meter and a small sample to check and adjust accordingly. I can usually nail it down in the 11-14% range with the right pick but usually it’s 38 or 32 on top of a light factory tint.
Edited by Naples Tint Company
Share this post
Link to post
1 hour ago, HardyHarHar said:
Thanks for the advice.
I re-ordered.
This time 30%
That should do the trick.
I pulled all the 50% back off before it dried.
If you want it to be a little difficult to see inside, you should probably go ahead and order a 20% down to even a 15%. Hard to say for sure, without knowing the vehicle. I put 30% on top of factory tint for the dealership every day. You can see right through it.  I wouldn’t get too hung up on the actual % reading, the same % can look completely different on 2 different cars. In most cases, trucks and SUV’s need a little darker % on the back to achieve the privacy your after.
Share this post
Link to post
Thanks,
I know it won't be Limo dark but that's ok.
I decided 30% laid over factory would probably be the best compromise.
Did some more thinking and going too dark might make it a bit difficult to see out at night, for me anyway
I guess it's not that easy to see inside now except in the brightest sun light because the fronts are 20% so the 30% over factory in the back should do.
Plus the possibility of attracting LEO the darker it gets.
No big deal to change it later if I want to.
Share this post
Link to post
7 hours ago, HardyHarHar said:
Thanks,
I currently have 35% over my factory windows on my 2006 GMC Sierra. They meter to either 7 or 8 on my Enforcer II.
My most common request when going over factory has been 15%. I have had a small handful ask for 5% over their factory tinted windows.
If you are just looking for a little extra and to still be a touch darker than the fronts you should be just fine adding the 30% over top.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
