filmvinyldesigns.com
Tint Tek 2020
spacer
Tint Tek 2020
spacer
Mr paladin
For the plotter experts
My first assumption is that tensioner isn't holding properly. May be a simple as changing out that top roller. I might would call up a distributor and see if they have ran into the issue.
Share this post
Link to post
:yeah Every time I've run into this issue it's been because the tension for the pinch rollers got knocked loose. I have the same (or very similar) plotter, check on the back of the pinch rollers that the lever is all the way down, they have three positions and I'd be willing to bet that the one on the left is in the middle position instead of the lower like it should be.
Edited by highplains
Added pics
Share this post
Link to post
2 hours ago, Mr paladin said:
Anyone know how to fix this problem? settings maybe?
What speed are you running that material? Have you cleaned your rollers with alcohol? That material is running awfully fast
Share this post
Link to post
