suntekfilms
armolanusa.com
tintwiz.com
Patterns.3M
Xpel
spacer
suntekfilms.com
armolanusa.com
tintwiz.com
Patterns.3M
Xpel
spacer
Long027
Mobile Tinting "Efficiently Tips"
As others have said reverse role is key. Especially in a mobile environment. High top Sprinter van or Ford Transit. Peel Board mounted to the wall inside the van.
Edited by Old timer
Share this post
Link to post
When I gave up auto, my typical install was 90 minutes for a sedan. As I recall, my system was this. Clean spray board, clean inside of rear window. Cut all door patterns and shrink as needed ( not double cutting ). Cut rear window and shrink as needed,  at that time it was also common to splice on defroster lines. ..next would be to re clean rear window and install the film. Next install 2 fronts, then install rear doors. I was never a panel puller,  I was always able to use my knife to slide behind the sweep and let the film drop behind it. Saves a ton of grief.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
