Patterns.3M
spacer
Patterns.3M
spacer
Sign in to follow this
Loud and Clear Audio/Tint
2018 Porsche 911 turbo S
remove the vent completely and flush and clean it out thoroughly then flush it out again and when you install the film go lighter with the slip solution around that area so it's not dripping.
Share this post
Link to post
we use a pressure on demand steamer and steam it 3-4 times before any install , also we use soft cloth with thin car wrap squeegee for edges.  but flushing them with steam does great.
Share this post
Link to post
I've just recently completed several wraps on new GT3RS's and they are indeed using double side tape.  You can easily fix this though by using a flat pry tool and just slide it in to break the bond, do not pry with it as you can dent the thin body panel, you must slide it in and out not pry it but it will easily come off.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
