Xpel
armolanusa.com
tintwiz.com
Xpel
armolanusa.com
tintwiz.com
Sign in to follow this
tint~guru
Cloth seats and door panel stained
Has anyone ran in to this problem? Some cars have light beige cloth panels and seats and they get stained with the water solution. What have you done to remove the stain?
Share this post
Link to post
I don't have any advice for removing the stain, you might get lucky and have it dry out, but my advice would be to cover the area during the application so it doesn't cause a problem to begin with. I use some large towels from Walmart that were cheap.
Share this post
Link to post
If it's older and doesn't get cleaned often you're probably just spreading dirt that was already there. Just clean up after, using upholstery cleaner like blue corral or even foaming glass cleaner.
Share this post
Link to post
Always recommend to cover the panels. Edge film has some really great reusable covers or home depo sells pre-mask shark skin that is pretty reasonable.
When you still get part of the cloth wet you might wet the entire area so when it drys you don't have the stain line. Just saying...works!
Cheers
Share this post
Link to post
Window tinting solutions also have an effect on streaking.  If you only use Film-on to clean, install and then to clean the glass after your install, there isnt much of a streaking problem on panels.
Share this post
Link to post
Never really have a problem, especially since panels are off most the time. If it does gets wet, I wipe it down right after positioning the film, then squeegee it out.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
