Johnny Mc 1 Report post Posted February 6 When trying to wrap the edge, can not get the two front curved corners to stay down on the under side of hood. Any suggestions? Share this post Link to post
Midtown Houston 377 Report post Posted February 7 Pro bond...suppose to do that before install 1 pottsnpanz reacted to this Share this post Link to post
Johnny Mc 1 Report post Posted February 7 15 hours ago, Midtown Houston said: Pro bond...suppose to do that before install I am using Xpel edge prep before install Share this post Link to post
Jake 307 Report post Posted February 7 Edge Prep/Probond is a solvent. If you put it on a before install it is going to dissipate for lack of a better term. Use it right before you press the area down. Just let it dry for a few sec and it will stick. 1 XPEL Jeff reacted to this Share this post Link to post
redneckj 60 Report post Posted February 9 I normally clean the back side of the hood with 99% alcohol or adhesive remover. I install the hood then flush the film that will wrap around to the back side of the hood with my Tac solution (8oz 99% alcohol and the rest distilled water). After that, I blow dry with compressed air. Let air dry while installing more Xpel. Then come back with the heat gun, warm the film that will wrap and wrap away. Never a problem with the Xpel sticking while using this system. Share this post Link to post
pottsnpanz 5 Report post Posted February 11 What film are you using? We use Xpel PPF surface prep on the bottom corners or trouble spots. Share this post Link to post
