TintWizard
2019 Mazda 3 sport and sedan
The bottom sweeps pull out and reinstall without issue , bottom load and it’s easy . I personally pop 3 of the 4 top panel plugs to make it a bit easier but unfortunately, the plug on the most outer edge is the same as the cx5 which will most likely break if you try to pop it so leave it in tact.
Share this post
Link to post
They are now in the database, I will try them out after the next few days and if there’s any tweaking or peeking,ill make sure it happens
Share this post
Link to post
The sedan patterns are good, the hatch didn’t scan right. Might be a few days off that one to get fixed they said
Share this post
Link to post
so just pull back on the top of the panels or does bolts need to come out
Many different ways for different styles of tinting. My preferred way is to pop the top row of plugs and one screw where the handle is. Unfortunately they replaced one of the plugs with a one-way plug but that’s OK, you won’t break it and you can still get the seal in an out without popping that plug. It’s the same plug that’s in a cx5 . Really dumb design unfortunatelyIMG_0501.jpg
Share this post
Link to post
