suntekfilms
armolanusa.com
tintwiz.com
“Patterns.3M”
Xpel
spacer
suntekfilms.com
armolanusa.com
tintwiz.com
Patterns.3M
Xpel
spacer
Sign in to follow this
pbalentine
No more convertibles
Glad to say i will f’ing never tint one again!  Just did one and had trouble with the bg and told the guy i aint doing it. He was cool with it and I just did the fronts.  Next customer that calls asking for a quote on one; my reply will be ‘F that!”
Share this post
Link to post
I probably do one a year if that, so wont matter. The risk of damaging the top alone makes these not worth doing.  Plus, theres never enough room to clean and install. Just f’ them all!!
Share this post
Link to post
1 hour ago, jh812 said:
So you had a pretty good day then 😂
Haha!! I actually did think, this ruined my entire day!! Im kinda still pissed thinking of it.
Share this post
Link to post
6 hours ago, TINT said:
i dont get it, what kind of conv was it? who owns in AZ anyway:joedirt
It was a Fiat Spider.  I agree, its too hot for convertbles here.
Share this post
Link to post
So what was the issue? Not being smug, but I don’t usually have an issue with any convertibles. Lay the film on the back window, instead of cutting use your white hard card to mark all the way around it. Transfer it to your peel board. Cut a little larger than 1/4” off the mark. Heat bottom. Shift down. Heat top. Every once in a while I’ll need to slightly trim on the inside, but it’s a rarity.
Share this post
Link to post
I had the perimeter perfect. Traced with dry erase marker and trimmed 1/8” around it. Problem was that weird defroster tab with 2 wires on the side. I tried doing full coverage by doing 2 small slits, since the wires would not detach.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
