suntekfilms
armolanusa.com
tintwiz.com
“Patterns.3M”
Xpel
spacer
suntekfilms.com
armolanusa.com
tintwiz.com
Patterns.3M
Xpel
spacer
Sign in to follow this
Guest AJ33
Is this normal? Bubbles around edges after tint job
Guest AJ33
Is this normal? I payed 200 for this install I would expect perfection at that price but you tell me... I pointed it out to the installer immediately after and he said it is normal and will go away... will it? Looks the same 24 hours later... let me know guys...
 https://imgur.com/FfBv0qL
https://imgur.com/4tOPzH9
Share this post
Link to post
Well your perfection is up the what car manufacture that made the matrix. Some makes can be very bumpy with not only a raised matrix but imperfections that act like a piece of sand or dirt making it almost impossible to lay it flat with out sanding or some method of smoothing down the teflon. The paint itself is more like a non stick surface anyways. So I would explain that to your customers because Fords, Volkswagens and a lot of other vehicle makes have horrible matrix surfaces. Plus on top of that in the area where the clear dots between the matrix are smaller, theres less likely a chance the tint will conform to meet the glass. What model of car is that in the images?
Edited by VisualTinter
Share this post
Link to post
After looking I'm thinking this is an older car, one that has either been tinted before and what you're seeing is dirt or old adhesive, but if it's your only gripe I'd say your guy knows what he's doing, don't be a dick about it maybe write a good review I promise I've seen much worse. Gs300? What car?
Share this post
Link to post
