armolanusa.com
tintwiz.com
Patterns.3M
Xpel
suntekfilms
spacer
armolanusa.com
tintwiz.com
Patterns.3M
Xpel
suntekfilms.com
spacer
Sign in to follow this
OverLord
Any tips for the new Blazer?
1 minute ago, OverLord said:
I'm just wondering if the sweeps pull out or not
Yep the sweeps will pull, the panel will lift off the sweep similar to the new Traverse. You need to remove the screw behind the handle, 7mm. It also helps to remove the upper trim from around the window to gain a little more clearance to the quarter window. I also trim the rubber around the quarter. Overall the quarter pushes them into "pain in the ass" territory for me but they're easy otherwise.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
