armolanusa.com
tintwiz.com
Patterns.3M
Xpel
suntekfilms
spacer
armolanusa.com
tintwiz.com
Patterns.3M
Xpel
suntekfilms.com
spacer
Bubbles
Wet sanding black borders
Having trouble laying down the BG on a challenger with the dot matrix also around the rear quarters. Getting that line in between  Is it normal to wet sand with 320 to relax the edge to get it to lay down. Thanks for the help.
Share this post
Link to post
You wont see some or all if the line at first because water is floating there. As it drys, the matrix line will be visible. You dont need sand paper on that one. I only use 1500 and 2000 grit for extremely thick defroster lines.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
