Tint sequence
Guest crewdog10
Guest crewdog10
I usually work in the same sequence for every car.
1)Tape seals and remove any trim or rear deck
2)Rinse car and rub dryer sheet
3)Shrink rear
4)Cut rear and all sides
5)Install rear
6)Razor, scrub pad, install side glass
What order do you guys work in?
  • Replies 31
we have two guy do each car...I do the rear window and my installer startes removing the door panels...he will usually cut all the doors and has the first window installed when I'm ready for him to help me put the rear glass film in..then he starts the rear door glass...I'll finish my back and then do any stationary back door pieces and prep any untinted doors for him, then I'll start to reinstall door panels and do the paper work while he installs the last door panel....we remove all door panels and most rear decks...
Guest tinterjim
clean all windows on outside of car
set up back glass for shrinking
cut all sides
shrink and install back glass
then install all sides
Guest nautiboi73
clean all glass inside(blade) and out (rubdown).
tape of felty
Cut sides
Cut back glass
Shirnk back glass
Reclean each with scrub just b4 install (sides).
reclean back glass with Scrub again.
Install back glass.
send to car wash :thumb
Guest thetintshop
pull car in
smoke a stogie
tape all felts
shrink back glass
remove any necessary decks or lights
smoke a stogie
clean inside back glass
install back glass
smoke a stogie
cut passenger side doors
clean glass
install passenger side doors
smoke a stogie
cut drivers doors
clean glass
install drivers doors
smoke a stogie
clean all ouside glass
take money
smoke a stogie and check out tintdude.com
Guest crewdog10
smoke a stogie
smoke a stogie
smoke a stogie
smoke a stogie
smoke a stogie
Damn! I counted six stogies on one tint job. That's like an hour in stogie smokin alone. :thumb
    2. 7
    6. 11
    7. 11
