citroen c3
matty cox
Guest Alfa 156
Front 1/4 lights bit of a pain but got them in ok, rear window took some time bit curvey but laid down ok  :shock
Hey Wiz........Having a bit of trouble getting the bottom to lay down.........I got the top sorted but the bottom is on the verge of over heating and under shrinking.......If that makes any sense.
Any tips for the bottom edge or is it just go for it and hope.
I did it dry (Baby powder) method cos wet was just an open invite for creases.
Do you find working from the middle out to the edges better on a dry shrink?
On a wet I was taught to work outside to inside but the dry method is something I'm picking up for my self and a few pointers would be really good.
Cheers.
156
Guest naughtydog
sound like you've overcooked thge bottom if it does'nt wont to lay down on the glass when you're mounting it. Sometimes it's best to give it some heat and then move away, do another area and come back to it, gives it time to relax almost.
Naughty
Guest Alfa 156
Cheers Naughty.
Patience prevailed and the job was finished today.
Couple of pics of the problem and then the finish.......rewarding though near suicidal when we first attempted it.
156
Guest Tint Wiz
sorry alfa did not get back to you got a 4 week old baby ,and not had much time to get on web site of a night ,if you get one again use a low heat on your heat gun ,and take it slow that should do it :dunno
CHEERS TINT WIZ ard.co.uk
    2. 6
    4. 6
    6. 11
    7. 11
