92 park ave
tint_audiopros
have the tinter take out the rear deck for proper job of tint under brakelight(if legal in your state). Also make sure he knows about proper dot prep(I belief this style has dot matrix on top of window and will look like :poop otherwise :eyebrows
If memory serves once you remove the rear deck and your taking out the brakelight , there a black cover covered in some sort of "tar" :poke You remove that revealing 2 sticky 10mm bolts .
Also the 2 front triangle windows have to be heatshrunk (use the factory edge to line up to the straight edge of the window and shrink the opposite side of the straight edge) also cut a bit of rubber out along the straight edge of the front triangle windows. They suck but come out clean when done this way :shock
Guest haroldshouseoftint
If memory serves once you remove the rear deck and your taking out the brakelight , there a black cover covered in some sort of "tar" :lol You remove that revealing 2 sticky 10mm bolts .
Also the 2 front triangle windows have to be heatshrunk (use the factory edge to line up to the straight edge of the window and shrink the opposite side of the straight edge) also cut a bit of rubber out along the straight edge of the front triangle windows. They suck but come out clean when done this way :poke
:nono:lol
Also pop the rubbers out of the doors, top of the panel pulls back enough to get em out :shock
That tar sucks azzzz
