Viper 791xv installation connections
Guest Diehardrod
  • Replies 41
I am trying to install the 791xv in my van and I have no idea where the remote start activation wire(h1/3), the second unlock output(h2/6), or the 2nd status(h3/1) goes or the onboard starter kill. I also have no idea where the four smaller wires on the relay satelite connect. I definetly need more experience in this field, I know. and the install guides tell me what the wire do but not where they go
Guest zolar
2nd unlock would dis-arm any oem alarm input
or activate a 2nd unlock relay for cars like the camaro that have 2 unlock relays
2nd status would be used to trigger a module to bypass oem immobilizer circuits
start activation comes from a keyless or seperate alarm to activate remote start function
the 4 smaller wires in a ribbon cable plug into the alarm brain connecting it to the satellite relays
you picked a difficult DIY project :lol2
you picked a difficult DIY project :thumb
the ribbon comming out of the relay satelite is 7 wire and if you look on the last page of the install guide its the four to the top right
**never mind the quote
so I dont need the remote start activation wire?
the ignition wire connect to the ignition wire before the key right?
and the pink output to primary ignition im guessing 12v+ after the key?
what about the anti-grind? I have an '89 van
really need help ith that 4 pin harness on the satelite
Guest NightWatcher
Hello,
This is a great site! I was wondering if someone might be able to send me the installation manual for the 791xv...I already have the user manual from the link posted here (thanks!)...Please offer help to this young bastard :P TIA!
NightWatcher
I forgot to give my email: nightwatcher@punosoft.com
thanks again!
Guest spooken
Hello,
NightWatcher
thanks again!
Never mind I found a copy of the guide.
http://www.directechs.com/guides/manuals/I.../N564V_6-03.pdf
The link has been posted on the same thread, you just need to scroll up.
    2. 7
    6. 11
    7. 11
