Flat glass - Duel pane
Guest steve-j
To all
Hopefully the answer will be as brief as the question. Can Argon gas filled Double glazed units be tinted ?
[*]218044
Yes... dual-pane specified films only... argon/krypton gas-filled or dead-air :lol still dual-pane. LLu's film-to-glass chart recommends it be treated as low-E dual-pane, which can be tinted, too.
Guest steve-j
To all
[*]218044
Yes... dual-pane specified films only... argon/krypton gas-filled or dead-air :copcar still dual-pane. LLu's film-to-glass chart recommends it be treated as low-E dual-pane, which can be tinted, too.
[*]218045
Thanks alot
Guest skeeter
:lol6 If you go by using only an absorption rate percentage you'll encounter problems. Dual pane needs unusual shading consideration and altitude consideration, to mention just a couple. This time of year films with absorption rates in the 30's snap glass all the time cause the installer looked at the films absorption rate, saw less than 50 and did the job. Then consider the scenario: it was annealed with a column running straight through it. :lol6
    2. 7
    6. 11
    7. 11
