Shrinking around hardware
Guest metint
Remove buttons, clean glass, dry laminate a small scrap of film to the glass exterior covering each hole, anti-static coat glass surface, lay film for shrinking, shrink, remove film for install, remove hole covering scraps, and replace hardware.
Has to be my shortest informative post ever... :thumb
You lost me Metint..what is the purpose of covering the holes with scrap film (if the answer is too obvious..keep in mind I just rolled out of bed and still asleep :thumb )
[*]218369
That's because I didn't explain why to do this. :rock
When hardware buttons or their holes through the glass become an challenge in heat forming nicely around them, remove the buttons and cover their hole over with a scrap piece of film.
This give you a flat surface rather than a hole during heat forming, which will go a long way in minimizing puckers in those areas.
Help any? :rock
I wrote it at 2 in the AM hour so go figure...
Guest metint
Thanks Metint! Never thought to try that. :evilgrin
[*]218381
It's rare to use this, but it does keep the heat form surface smooth and free of pesky holes.
Guest zolar
I am gonna try that one. :twocents
Nothing worse than getting a back glass shrunk, after removing 100 lbs. of hardware, only to hold the heat over the hole too long, and have pucker.
I am too picky to not lay 'em down, even if I have to start all over.
And I love wasting 4-5 ft of film, and a half hour, makes me very pleasant company.
Z
    2. 5
    3. 5
    4. 5
    5. 5
    6. 5
    7. 0
      INDIANAPOLIS, INDIANA NOW HIRING FOR AUTOMOTIVE WINDOW TINTER
    8. 0
      Window Tint Training For Groups Or Individuals
    9. 3
      Tinting is annoying, i need help
    10. 0
      3M Experienced Flat Glass Installers Needed In Sunny West Central Florida
