Concord films
Guest clatin
Guest Riddler
www.concordwindowfilms.com
My assumption is that they distribute some other manufactures film under their own label. Possibly, one of the two you mentioned or some other company.
BTW...
The do list a fading cause chart unlike any that I have ever seen-
40% Ultra Violet Light
40% Infa-Red Light
10% Visible Light
10% Other causes - not related to window films.
:inot
their site says they cater primarily to the DO_IT_TO_YOURSELFER market. I think that says it all.
pretty cheep privces on some of that stuff, might be worth getting if you just want to "SLANG SOME PAPERS" on some homies vehicles.
Guest TintPoser
BTW...
40% Infa-Red Light
10% Visible Light
:coffee
[*]273586
Yes and no......
it's more like
25% Visible Light (if you use the inductry standards, But since Visible is part of heat, you should get to count visible for another 12%)
25% Heat (53% IR, 3% UV, 44% Visible)
10% Misc
40% UV
This is a SIMPLE explination for fade. if you considerr the types of lighting, the exposure, the ambient temperature, the different types of material that are fading, chemicals in the air, altitude, moisture in the air........ there is no chart to show you fade.
Actually the first chart is definitely wrong, the second one is one of a many possible charts depending on what is suffering the fading problem. It is a lot more complex than that, really, but as a rule of thumb :the less something fades, the more it is due to UV, percentagewise. the more something fades the less we can help with blocking all the UV. fading doesn't necessarily have to do with the quality of the product that fades.
[*]273730
:coffee:chick
Guest metint
Does concord film stand up to llumar or Madico films?
[*]273544
Isn't Concord a DIY Sungard film... maybe gives Gila film a run for their money? :DD
      Low angle haze
    2. 4
      Low angle haze
    4. 4
      Low angle haze
    5. 4
      Low angle haze
    6. 4
      Low angle haze
    7. 0
      HIRING INSTALLERS - full time positions Vinyl Graphic Installers
    8. 0
      Colorado Tint & PPF installer(s) needed!
    9. 0
      Tinter looking to relocate
