I have RR...and my comp is running slow
Guest Marco
Ok..you must have forgotten what I wrote last time you were hijacked..Ok do this.
Go to www.pcpitstop.com run a test and find everything that has to do with norton it will show you in the summary what is running and what the program does (also good for viruses). After the test click start, run and type msconfig in the box, click start up and uncheck all the junk you don't need running in the background, find all the norton start ups and uncheck the boxes. Apply and restart computer,after it starts check the box in the warning and close it. You do not need a firewall it can cause more problems than it's worth..you need a good program to block anything trying to install itself, that program is http://free.grisoft.com/doc/Get+AVG+FREE/lng/us/tpl/v5 at the bottom of the page is the free download. Go to Downloads.com and get ad-aware and spybot, they work best together. Run sbybot then ad aware and get rid of junk slowing down your system. If it's not a virus most likely it's a program or applications running in the background that will slow your system down, easy fix. Always delete cookies,files and history before running tests and defrag often.
[*]279175
That's what I run too! :coffee
Works well and it's FREE!
Guest zolar
Good advice marco, I did as you suggested and also got firefox and thunderbird from mozilla, my pc is running much better. Maybe I am finally through with Microshiot security flaws, and spyware, and norton's failures to keep out the critters. :rollin
Z
Good advice marco, I did as you suggested and also got firefox and thunderbird from mozilla, my pc is running much better. Maybe I am finally through with Microshiot security flaws, and spyware, and norton's failures to keep out the critters. :nope
Z
[*]280378
we also you firefox from mozilla at the shop...works like a charm. :rollin
    d2iwindowfilm.com
      Independent Contractors needed for Security Film Project- Houston
    5. 4
      Mutoh Plotter
      Reveal Molding/Belt Moldings
    8. 4
