Punto <1999
Guest Fragger
Guest Fragger
I just wondered if it was possible to remove the rear window catch on the rear windows in order to make it easier to tint the windows.
I can remove the whole glass section with the catch but then cant seem to find a way to remove it. Does anyone have any ideas ? If not tips for appling tint around this obstical.
Guest Mrs RJE
RJE says the only way he's found to get one of those catches off is to drill out the rivets that hold it on, and order some more from Fiat.
Sorry I couldn't be more helpful :rollin Good Luck
Guest da_stripperboy
drilling the rivet and twisting the cap holding it in place is the only way. you can just slide the pins you drilled back in without it causing any problems
      Contravision
    2. 29
    4. 3
    6. 4
    7. 3
    8. 4
    9. 3
      New tint. Not happy
    10. 3
