outside temp for applying tint
Guest tooeviltwin2
Guest tooeviltwin2
What is a good temp to start applying the tint when you are working out side?I live in Tennessee and it is around 90 degrees today.
Guest darkdan
Don't do it below 40 degrees or so. One time I turned around and the tint fell off a window. =( Now I have a 100,000 BTU space heater. =)
When it's hot then tinting can be a PITA if you're in direct sunlight.
Guest tooeviltwin2
[*]293141
Explain PITA please and thanks for the info. I don't think it is going to be 40 degerees for quite a while. :krazy
Don't do it below 40 degrees or so.? One time I turned around and the tint fell off a window.? =(? Now I have a 100,000 BTU space heater.? =)
[*]293141
Explain PITA please and thanks for the info. I don't think it is going to be 40 degerees for quite a while. :wall
[*]293145
PITA-probably means Pain in the azz.- Why you workin outside? :wall ss
Guest nautiboi73
in direct sunlight you are going to have less "working time" with the film. might also get hot spots, spots that sticks more than the rest of teh film. As the temp changes you will need to alter your SLIP soultion so that it is not too slippy and not too tacky. Hot= more slip needed
Cold =less slip needed.
    Tint My Ride
    rewiredtech.io
      Graphtec Plotter
    4. 1
    5. 1
    6. 4,178
      What did you tint today?
    7. 1
    8. 4
    9. 4
