Get More Ho's
Guest zolar
After searching the bolts around the shop, I found the thread on the steamer is the same as air tools. A trip to the big store yeilded a 50' extention for $8.99. A 50' will go way out into the yard. I am going to add a rubber-tipped sprayer and quick-connects for those corners and edges. If you are into the steamy stuff, Z will help you find more hose.
Guest ninjatinter
Look at you Z, all into the steamer :DD Seems like yesterday you were like" what the hell are these things for??? P.S. You should get yer "big sore" looked at!! :evilgrin
After 50' do you get steam or cold water????
Steamers rule.
[*]306545
Still sprays steam :evilgrin
the coil acts as a condenser though and it spits a bit more.
Al, You we're one of the first to suggest the steamer :DD
I still sweat most of 'em with all this heat outside.
Z
