truck lowering
Guest tintgod
  • Replies 23
Guest tintgod
details of the problem?
[*]306714
ok...I installed 2.5 " drop spindles and 2" drop coils..that is 4.5" right?..well...wene I measure the drop...from origanal height specs...it dropped 5 inches :phone
anyways..im thinking it is too low,,cus the tires rub on the inner fender wene you turn sharp
should I raise it back up with factory springs..I want it to set level if paossible
and suggestions...?
factory ride height is 32" in the front..and 34" in the back..(this is measured from ground to top of wheel arch)
I am sitting at 27 in the front and 28-28.5 in the back
ok...I figured it out..im going to take the lowered springs out of the front that should bring it up to 30.5" and with the back being 28.5" that should make it level ..I hope.. :duck
      Contravision
    2. 29
    4. 3
    6. 4
    7. 3
    8. 4
    9. 3
      New tint. Not happy
    10. 3
