Any impact from polishing, if the mar responds to polishing, would result in no or little visible trace.
Anyone experienced in buffing glass will likely say, no guarantees; unless they've experienced the same mar on glass.
I use(d) these that are readily available through grocery stores; on installs that should not have a blade running across their surface.
https://www.walmart.com/ip/Scotch-Brite-3PK-Dobie-Cleaning-Pad/580762256?wmlspartner=wlpa&selectedSellerId=101033794&gclsrc=aw.ds&&adid=22222222227580762256_101033794_160178497084_20981201920&wl0=&wl1=g&wl2=c&wl3=689850595863&wl4=pla-2274697737319&wl5=9008682&wl6=&wl7=&wl8=&wl9=pla&wl10=255470249&wl11=online&wl12=580762256_101033794&veh=sem&gad_source=1&gclid=EAIaIQobChMIyo335LbOhQMVo0tHAR1HpQC8EAQYASABEgKydfD_BwE
Need to know whether the boat has glass or does it have plexiglass (acrylic) or Lexan (poly-carbonate). Glass is not worrisome, the other two are.
Plexi will blister from out-gassing in no time at all, whereby, Poly-carbonate is a crap shoot as to when and how serious, if any, blistering of film occurs.
Both Plexi and Ploy may also be difficult to remove, if the need arises down the road mainly getting the adhesive of without damaging the surface.
Both should not be warranted given the aforementioned potentials and these conditions should be discussed with the owner.
no, aside from window cleaner I’ve not tried anything else yet like goo gone, a razerblade, etc… I’ll probably leave that to the detailer.
question: when polishing glass will it impact the visibility after? I guess I’m now weighing between having them try to correct it or just leaving it be.
I start those at $750 and go up.
Best advice is no cutting on the glass and white scrubbie only, no cleaning blades. That glass is super soft. You may want to use a film liner to make a template to cut your patterns.
Hi! I’m new to the tinting world. Just completed a 5 day tinting course and want to purchase some films to start my mobile tinting. We trained with Geosheild, but there was a lot of talk about Maxpro and how it was good as well. Does anyone have experience with both of these? Which one is better to work with and easier to shrink? Prices on both are pretty close to each other. Any advice would be greatly appreciated.
thank you!
