Application Solution
Guest swanny
What are some of the application solutions that you use for installing vinyl lettering and graphics?
metal ?
glass ?
plastic ?
Or do you buy whats on the shelf at your local product sign supply store ?
will alchol destory the glue on vinyls?
When layering vinyl do you do it before you install it on your subsrait
or do you apply the layers to the the subsrtait one layer at atime?
Guest afterhours
normally on metal,glass, or plastic I always lay my first layer dry unless its just not possible.(if its to big etc.) when not possible I have used ProPrep but normally I just use a little soap and water. I have used alcohol but I'm not sure about the long term effects. as for layering, I use heavy soap and water. if the decal is small enough for me to handle I will lay the second layer dry and then tape it.
Thanks for all the info
You guys have been a great help with all the information on window tinting
I have been doing tinting for about 9 months and with all your information you have given me I have exceled pretty fast Thanks
Know sence I have a plotter I will add graphics to my company
talk to all of you later. :lol2
Guest HeatShrunkSS
talk to all of you later. :spit
[*]314963
Why are you installing wet??
Sure, there are some circumstances where it's easier to install wet, buy primarily I just do a dry-stick........alot quicker and no dry-time.
    2. 7
    6. 11
    7. 11
