Anyone have wiring info for Town & Country
I know this vehicle requires a couple extra relays and a bunch of resistors to make things work properly. This van has a single wire door lock system that needs resistors installed for lock and unlock, and, from the data I have now, needs a resistor installed on the starter wire also.
I am trying to do an install estimate for a customer, but need an accurate wiring diagram for this vehicle before I can give an accurate estimate. I always like to have two sources of vehicle wiring diagrams for all of my installs, and I can only find one for this van.
If anyone has one, it would be much appreciated.
Guest kccartint
A little late but here is a DEI Sheet.
12volts lt. blue/red (10A) + ignition harness
Starter yellow + ignition harness
Second Starter purple/brown - ignition harness
Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1083 for wiring information.
Ignition pink/white + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory not required for remote start
Second Accessory N/A
Keysense N/A
Power Lock purple/dk. green - BCM, white plug, pin 21
Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Can also use Directed 456L interface modules.
Power Unlock same as power lock wire
Lock Motor tan/white 5wi BCM, green plug, pin 10
Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Unlock Motor tan/lt. green 5wi BCM, green plug, pin 28
Parking Lights+ white/brn (L), white/org ® + driver kick, harness to rear
Parking Lights- white/brown - switch or BCM, gray plug, pin 21
Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See DirectFax document 1082 for wiring information.
Hazards white/dk. blue - switch or BCM, gray plug, pin 31
Turn Signal(L) wht/lt blu (F), wht/dk grn ® + BCM, green plug, pins 1, 2
Turn Signal® white/tan (F), white/brown ® + BCM, green plug, pins 3, 4
Reverse Light white/lt. green + BCM, green plug, pin 9
Door Trigger see notes - BCM, white plug
Notes: The driver door trigger is purple in pin 6, the passenger door is purple/white in pin 7, the left sliding door is purple/gray in pin 8, and the right sliding door is purple/yellow in pin 5. Use all four wires and diode isolate each. Also have to diode isolate from the BCM. Refer to DirectFax document 1076 for wiring information.
Dome Supervision yellow/brown or yellow/white + BCM, white plug, pin 33
Trunk/Hatch Pin purple/orange - BCM, white plug, pin 29
Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
Hood Pin purple/lt. blue (export model) - BCM, white plug, pin 30
Trunk/Hatch Release purple/tan - BCM, green plug, pin 6
Notes: Hatch release is negative trigger thru a 1.69K ohm resistor. MUST use a relay.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.o notes.
Power Sliding Door purple/dk. blue - BCM, white plug, pin 1
Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT brown/white ac ign coil pack or any fuel injector
Wait to start N/A
Brake Wire white/tan + brake pedal switch
Parking Brake dk. green/white - parking brake switch
Horn Trigger dk. green/purple - steering column
Memory Seat 1 purple/brown - BCM, green plug, pin 24
Notes: Memory seat 1 is negative trigger thru a 6.8K ohm resistor. Memory seat 2 is negative trigger thru a 2.1K ohm resistor. MUST use relays.
Memory Seat 2 same as memory seat 1 wire -
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Sentry Key
Part #: 556CW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Thanks... I knew this one was kind of nasty with the single wire locks, resistor needed on the starter wire, etc. No problem with the timing on your reply, I needed it mainly to give the customer an accurate estimate... hopefully he schedules it.
