Plotter system
  • Replies 47
I have never used a plotter for anything, and I am not a plotter basher. I have considered purchasing a small vinyl cutter to do only custom work. When considering the use of a plotter for cutting regular work, I have totally disregarded the idea.
Looking at my typical installs, less the 1/3 of the time is spent on cutting, and that includes shrinking. Removing shrinking from that equation, I estimate that appoximately 1/4 of the time is actually spent on cutting. That is not an area that I would consider when trying to make my work more efficient, JMO.
Guest privacy_tinting_uk
[*]326363
:bingo
my plotter is like way old..called a filmhandler..holds up to a 60 in roll...I use it all the time....
no really I was thinkingof a plotter last year....usually when it gets slow...figuring I could use it for paint protection film and tint....but when I get past the slow time and I;m tinting 50 to 60 a month..I figure f the plotter and pre cuts paint protect and all the cool stuff I can do and I just tint if you got extra cash it seems llike a cool toy...but not necessary and not needed....beside those of you who use them are the cuts as good as you can do free hand.....the ones I have seen I do a better closer cut.... :bingo
I dont see where switching rolls of tint back and forth on the plotter saves any time over the usual way to cut film :bingo I guess if you were using all 1 shade on the plotter it might be ok, but around here nobody gets light on the backglass :bingo so I would be stitching film back and forth all day :lol sounds like a pain.
The following is what I?m aware of as to LLumar PrecisionCut software, so you can compare:
Automotive patterns
Multiple rear glass choices
Pattern nesting for efficient use of material
Pattern rotation
Pattern size adjustment (does not save changes)
Multiple car cut capability
Two roll holding capacity
Flip or invert pattern
Flat glass
Micro-rounding of corners
Capable of cutting Paladian patterns
Safety Film up to 7 mil
Two roll plotter holding capacity
Paint Protection Film
Pattern rotation
Graphics
Vectorized graphic import capacity of these file types: .dxf, .aama, .gbr, .cmd, .plt, .abl
File import from Adobe Illustrator (thru Corel Draw) and Flexisign
Graphics Library (SEMA Intro)
Also handles Vinyl through the use of either a 40 or 60 inch Graphtec plotter.
There may be more I have not been introduced to. Ask someone in LLumar sales to elaborate. :thumb
Guest Sprinter
I dont see where switching rolls of tint back and forth on the plotter saves any time over the usual way to cut film :lol6 I guess if you were using all 1 shade on the plotter it might be ok, but around here nobody gets light on the backglass :lol6 so I would be stitching film back and forth all day :thumb sounds like a pain.
[*]326617
mdog's right switching out film yea that saves time....................
I dont see where switching rolls of tint back and forth on the plotter saves any time over the usual way to cut film :beer I guess if you were using all 1 shade on the plotter it might be ok, but around here nobody gets light on the backglass :thumb so I would be stitching film back and forth all day :lol6 sounds like a pain.
[*]326617
[*]326657
Yep... about the same effort it takes to swap rolls off a shelf... especially with a plotter capable of holdin two rolls... simple as release one film feed and slip in the other.
Wow... that wore me out.... :lol:lol6:DD
