Guest metint Posted October 13, 2005 Report Share Posted October 13, 2005 Interesting concept... both of them... Will have to put it top the test. Link to comment Share on other sites More sharing options...
tintinater Posted October 14, 2005 Report Share Posted October 14, 2005 On felt beasts I take the door panel off, if it's an older taurus the whole felt strip around the window pulls out, if not, sgueegee, flush gently, peel entire tint upside down on glass, lift tint from underneath on back of hands, thread front in first, curl back part in without ever touching felt, flawless. Link to comment Share on other sites More sharing options...
Mr paladin Posted October 14, 2005 Report Share Posted October 14, 2005 Link to comment Share on other sites More sharing options...
Guest sunbuster Posted October 14, 2005 Report Share Posted October 14, 2005 if I was close minded I wouldn't have opened the thread and wouldn't have asked a question. Excuse my English for I propably should have said "seems so much easier".Give us foreigners a bit more credit for having good intentions with what we try to say. And keep the tips coming, if they work for you they are worth posting. By the way what about using those liner sheets for the bottom gasket to be able to tuck in the film with the door panel in place? [*]326346 Kohler The tape works fine, but try this trink in addition. take a white or black teflon "hard" card (prefer black), cut it into a triangle. On your final cleaning, spray the window (no need to flush the edge, too much water is the enemy w/ this technique), wipe the top edge, then run the triangle down both sides against the window cleaning any loose felt, squeegee the window from across starting at the top, not hitting the edges and wiping your squeegee each time it is lifted from the glass. On the bottom when you roll the window up, lift the lower half of the film away from the glass, TRY AND KEEP YOUR FILM IN THE SAME DIRECTION AS THE PORTION THAT IS ALREADY INSTALLED! This will avoid creases and eliminate felt from breaking off. Lightly mist the window stay away from the edge, and squeegee the remaining glass. Wet you window, remove the liner, wet the film, and slip it in behind the lower gasket. You can use your triangle, or red devil trim guide (painter tool) to move the gasket. The triangle is great for squeeging water from the sides and bottom in tight or hard to reach areas. With a little practice your windows will be flawless. Good Luck Link to comment Share on other sites More sharing options...
Kohler Posted October 14, 2005 Report Share Posted October 14, 2005 By the way what about using those liner sheets for the bottom gasket to be able to tuck in the film with the door panel in place? Can you expand on this for me Kohler?? Naughty [*]326361 Sure. I never take off the door panel. After I rolled up the window I slip a piece of liner as wide as the window between the glass and the bottom gasket (Silicone side towards the glass). Slip it in about 2 inches, tape the rest, 8 inches or so to the door panel. Then I flush the bottom of the glass. Now I have the clean glass on one a clean liner on the other side and can cleanly slip the film in between. Hard card the edge, give some time before you take off the liner. Need more details? Cheers Kohler Link to comment Share on other sites More sharing options...
Kohler Posted October 14, 2005 Report Share Posted October 14, 2005 Sunbuster, I think that is what I am doing as well just using the conquerer with a papertowel. Link to comment Share on other sites More sharing options...
Guest metint Posted October 14, 2005 Report Share Posted October 14, 2005 Sure. I never take off the door panel. After I rolled up the window I slip a piece of liner as wide as the window between the glass and the bottom gasket (Silicone side towards the glass). Slip it in about 2 inches, tape the rest, 8 inches or so to the door panel. Then I flush the bottom of the glass. Now I have the clean glass on one a clean liner on the other side and can cleanly slip the film in between. Hard card the edge, give some time before you take off the liner.Need more details? Cheers Kohler [*]326588 Nope... got the first go 'round! I like it! Got to give then Germans credit for having ingenuity... not to mention great beer. See ya in Vegas, Kohler... Link to comment Share on other sites More sharing options...
Kohler Posted October 17, 2005 Report Share Posted October 17, 2005 see, ya metint. I'll bring some ingenuity, the beer I bring I owe to a Brazilian fellow for loosing a bet. Link to comment Share on other sites More sharing options...
FRANK Posted October 18, 2005 Report Share Posted October 18, 2005 Did you even take a breath when you were wording all of that ...damn by the way Link to comment Share on other sites More sharing options...
Mdog Posted November 11, 2005 Report Share Posted November 11, 2005 I tried this today and it worked very well. thanks for the TIP this is a drawing of what the guy is talking about. Imagine this as a top down view of a rollup window. The black is the side felt gasket, the blue is the window in the gasket and the red is the liner, it is rolled up onto by the glass and blocks off the dirty felt very nicely. Link to comment Share on other sites More sharing options...
