Helps rear glass dry quick
Guest clear image
didn't someone have an arcing problem when trying this? I remember a post about a shattered rear window, and if I'm not mistaken it was from doing this.
Not worth the risk in my humble opinion, it's going to dry anyway, why risk it?
Guest tintgod
[*]326468
:thumb ..I think I remember that also..I thing it was on a hoda passport or something like that..let it dry on its own
[*]326468
Yes, but if I remember correctly, that was attributed to an error on install. If you re-cut the film around the defroster tab after installation, you run the risk of weakening the electrical connection between the tab and the defroster system. That produces major current over a pathway that's too thin, and therefore produces high heat in a concentrated area.
its like heat shrinkin a windshield sometimes your lucky sometimes your not. :bingo
[*]326586
Or said another way...
In time, the improbable will become a certainty...
I used to work for a guy who pulled every car outside with heater running full blast and the the defroster on for like an hour, it was crazy, because every once and a while you'd have a car with a bad thermostat overheating in the parking lot, antifreeze everywhere..
    2. 6
    4. 6
    6. 11
    7. 11
