antenna
I just finnished a call look bug (someone else started it :bat )
I noticed that the antenna hole is filled in (no hole :mad ) and I really don't want to drill a new hole.
Anyone know if theres an antenna that can be installed on the inside of the car, like maybe on the w/s or back glass :bat
if you want FM any little rubber duckie antenna will work, even hid under the dash
a length of wire 31" long ( FM Quarter wave) will also suffice
AM requires a ground plane to reflect the signal back up into the mast
I have a little bug project too :mad
