Pep boys replacement side view mirrors
Guest ace_o_spades
wow I came to this late, this is my stuff I should pay more attention.
1) go ahead and remove the old glass
2) Use a flat screwdriver or something similar to pry the old glass off, might want to break it inot smaller pieces to make it easier, and be careful on to put too much stress on the mounting plate.
3) when the glass is all off, scrape the excess tape/adhesive with a razor and clean the surface with alcohol, clean the glass too
4) stick that puppy on with double sided tape, and get it on where you want it because you only have one shot.
Guest oldude26
heat the old mirror and scrap it off the back plate then use silicon on the new on and wrap masking tape around the housing to hold it in for about a day and you will be good to go
:trustme
Guest kurapika
I'm not sure if they can or will do that. But I do know that you can usually order a replacement glass specific to your vehicle. I believe mirrors are around 10 to 20 dollars. Try to check out some online parts stores.
    2. 7
    3. 7
    5. 7
    6. 0
    7. 11
    8. 11
