Knife set up
Guest ShadyKat
Guest ShadyKat
Assumption that the knife is in good condition)
For those of you that are using ClearSheild how much force setting do you set your plotter at?
And how do you judge that you are getting the wright cut? :poop
Guest ShadyKat
are you using the omega 100 plotter?
on mine I have to extend the blade about 3 mil and set the gram force 4-7 higher,  But I use a graphtec 5100-100.
there is a test button on the omega that cuts a square and  a circle to see if it is set right.
[*]359953
Yes I am using the omega 100. I have extended the blade and have adjusted the force to 220 grams. This just scores the release side. I didn?t trust the test pattern (because of its size) so I shrunk a full pattern down to about 15? or so. I have not cut that many PPFs and I am traveling out of my area on Friday for some training. The deal is I supply the patterns, so I just wanted to make sure they are acceptable.
