Newbie,Viper model 160xv Help!
Guest Big_N_bad
Guest Big_N_bad
I have a 1997 dodge ram 1500 and I have a viper 160xv remote start system on it. For some reason I cam home from work and I tried to start it, and it would not start. So I opened the door and Nothing happened. Nothing works, nothing lights up, It is like the car is locked out or something, I tried to jump start it but It doesnt even try to turn over, it doesnt do anything at all. Need help. Thanks
BNB
sounds like loose or dirty battery terminals
if the alarm was powered at all it would be screaming .....and killing the starter
no lights, no nothing........no voltage, or ground
:lol or aliens
Guest Big_N_bad
I know that is what stumps me too! There is abosolutly nothing working at all. It wont even turn over when jump starting. I have no idea. I need to get this fixed as I need the truck soon. It wont even turn over with the key on and turned to start. Thanks
BNB
Guest Big_N_bad
yea, reckon I should go and get a new battery, I will let you know what happens after that. hopefully it is just like a dead cell in batt or something. Thanks
BNB
Guest Big_N_bad
I have replaced the battery. and now everthing works like it should when I go to use the remote start but it wont turn over. All the pumps turn on and lights but the engine wont turn over. The radio works when I turn the key forward right before the start postion. It wont turn over at all but everthing elso works fine. thanks
BNB
Guest zolar
BNB
[*]385164
will it turn over with the key now ?
Guest Big_N_bad
nope everthing else electrical works and the remote start acts as it should but the engine wont turn over for some reason. Not with the key or the remote start. Thanks
BNB
      OG tinter
    2. 4
      Peanut Killer
    3. 4
      Peanut Killer
    4. 4
      Peanut Killer
      OG tinter
    6. 3
      OG tinter
      Peanut Killer
    8. 0
    9. 6
      Tack Solution When Vinyl won't lay flat
