Help on Crimestopper rs999tw1 02 Blazer
Guest umpbush
Guest umpbush
I am installing a Crimestopper RS999TW1 on a 2002 Blazer with a GMSL bypass module. I have found the Factory disarm wire(lt. green) at the purple bcm plug, but it is supposed to be reading negative and I am getting a positive 12 volt reading on this. Don't understand why because it's located exactly where the wiring diagrams are located and I don't want to hook it up with it reading positive. Any reason this is happening? Or somewhere else to look for the wire at? Hell, maybe I am just having a brain fart and not doing something right with the multimeter. Any help would be greatful and may turn a light bulb on to solve this so I can get this vehicle installed and going down the road.
Thanks
Brandon
Brandon
a BCM input looking for a ground pulse will usually read +12V
likewise a BCM looking for a +12 pulse will usually rest at ground.
unlike older cars that use relays, and usually rest at nothing
do you have a print on the blazer wiring?
the +12V you are reading will flash to a ground pulse on a meter
either the voltage shows a brief drop, (analog meters work better seeing pulses)
or the circuit will show continuity to ground when pulsed
Guest umpbush
Thanks zolar. I do have the print of the wiring and I am sure it is the correct wire. I guess I was just wanting reassured. I did notice the pulsing but like you said a analog would be easier to see it. Thanks again!
Brandon
      Peanut Killer
      Experienced Tint Installer Needed Immediately - Birmingham, AL
    3. 7
      Peanut Killer
    4. 6
      Great to be back to the best tint forum ever
      Ppf installer $200k annually
    6. 0
      Hiring A Flat Glass Installer
    7. 3
      OG tinter
