Guest benjamin Report post Posted March 2, 2006 I used stainless steel blade to cut tint out and later after I tinted the windows I was checking out the job with a flashlight and could see the faint outline of where I had shape cutted the film. Now is this normal? you can't see them with the nek!d eye, but shine a flash light on the window and presto there they are!! Share this post Link to post
Guest Al-tint Report post Posted March 2, 2006 (edited) Forget the flashlight. Park it outside. If you can see marks you will have to deal with it. They cannot be "buffed" out. Stainless blades will scratch glass, just not as easy as carbon blades. Edited March 2, 2006 by Al-tint Share this post Link to post
Guest benjamin Report post Posted March 2, 2006 Forget the flashlight.Park it outside. If you can see marks you will have to deal with it. They cannot be "buffed" out. Stainless blades will scratch glass, just not as easy as carbon blades. [*]377505 I see, looks like I might have to use that plastic tip technique, cause I don't want to deal with issue anymore, good thing it's a friend of mine. Share this post Link to post
Guest tinterjim Report post Posted March 2, 2006 Some glass is softer than others. In my years I've learned to be more cautious with certain makes and models. Share this post Link to post
shwusyrtnts 21 Report post Posted March 2, 2006 Click a blade off every cut!! Dont push hard and dont cut over the same spot more than once. Glass will scratch but that doesnt mean its okay just be careful and when your caught be prepared to replace it! Share this post Link to post
Guest vclimber Report post Posted March 2, 2006 Forget the flashlight.Park it outside. If you can see marks you will have to deal with it. They cannot be "buffed" out. Stainless blades will scratch glass, just not as easy as carbon blades. [*]377505 Yeah watch out for carbon blades you will be hating life if you use them. Share this post Link to post
shwusyrtnts 21 Report post Posted March 2, 2006 Oh yeah and make sure you wear goggles when you snap those blades!! Share this post Link to post
Guest losdawg Report post Posted March 2, 2006 Oh yeah and make sure you wear goggles when you snap those blades!! [*]377561 Share this post Link to post
Guest benjamin Report post Posted March 2, 2006 Oh yeah and make sure you wear goggles when you snap those blades!! [*]377561 just remember to snap-away! Share this post Link to post
Guest streetsounds Report post Posted March 6, 2006 or u could use the penny method just put a penny under the tint and cut the tint with the penny under it Share this post Link to post
