help with peeled skylight
Guest solar solutions
I tinted 5 skylights with solar gard stainless steel 50% cda.4 days later the customer called me only 1 skylight peeled off.went there and that was so.
I dont know why!
all from the same lot!
sklight are all the same!
skylights were cleaned
weather was direct sunlight @ 72degrees
Guest DontWorryItWillDry
SS,
was this an interior app or an exterior? and what type of adhesive system does the film have? PS or dry/chemical?
SSNY, not sure what to make of this. But if it was plexiglass, wouldn't you have known it when prepping the glass?
If it is glass, did the other ones that did not peel have a curling problem when the film was still wet? If so, did it curl on the top, sides, or bottom?
Also, was the direct sunlight hitting the skylights directly as you were applying the film?
is there a possibility the the installer got mixed up and unstalled that piece backwards? it happens :) I have a buddy that did it before, went back the next day and tint was on the floor :) I mean s**t happens, thats the only thing I can figure.
