Problem with FlexiSign 7.5
Guest Arabo
Guest Arabo
Hi!
I have a little problem with cutting out larger pic and texts with FlexiSign 7.5. It seems the pic or text gets a lower resulotion and half of the text or picture dissapears in the preview mode and when it cuts out the pic/text its the same. The corners that are round in the picture are mor sharpe and eggie.
But when im cuting smaler pic/texts I dont have this problem.
The cutter I use is a Roland GX24
Im attaching a pic of he invalid text.
Im thankfull for all help I can get.
Best regards
Richard Soleymani
richard@artreklam.se
If it breaks it up like that as you increase the plot size, the program is adjusting to compensate for the media size that is set on the plot preview screen.
There should be a default size and a "user defined".
Select user defined, and set it to fit the media you are using.
Then tab to 'panel' in the preview section and adjust it also. :bling
    2. 7
    6. 11
    7. 11
